archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Iroko, an exotic African wood, reflects a pretty amber color in sunlight. also called an “aquatic wood”, it is highly resistant to water.This shower is offered in 3 different versions :>Solo Iroko 50 x 50, with a 50 cm x 50 cm square grating - Weight 17 kg>Solo Iroko Rond with a 70 cm diam. round grating - Weight 22 kg>Solo Iroko Rond Encastré with a grating embedded in the structure but still movable - Weight 24 kg¼ turn faucet and accessories made of chromed brass, marine quality stainless steel screws and nuts. Ground fastening brackets allow installing it on a wood, stone or other type of terrace surface. Installation on a movable soil is possible with an “screw-in lawn anchor” supplied as an option. Thanks to the discreetness and warmth of the wood, this shower fits perfectly into highly diversified garden and swimming pool environments. Offered with a standard 12 cm dia. shower nozzle, a 15 or 20 cm dia. nozzle, a rinse feet faucet set or a small hand held shower nozzle are also available.To waterproof the wood and protect it from stains, it is recommended to apply Teak oil to it once or twice a year.
Weiterlesen...
Weiterlesen...
