archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Conventional Comfort Enjoy two rooms in the space of one with a multi-functional wallbed from Sico. Whether a home, apartment, or condominimum, a Sico wallbed is the perfect way to add more usable living space. The Sico Eurobed offers the sleeping comfort of a conventional mattress and European-style arched steam-bent slats that adjust to the body's contours. Three bed sizes are available - twin, double, or queen. Eurobed wallbeds can be used with either a Sico Silver Crest or Gold Crest mattress (quality bedding from Sico or the mattress/boxspring of your choice). The Eurobed wallbed raises and lowers with just a fingertip's pressure, regardless of the bed size. Sico's exclusive "Power-Pak" controls hidden inside the frame gives almost effortless control on all sizes of beds! Sico also offers you the opportunity to select the bed face and cabinetry colors that best fit with your home decorating style and existing furnishings: 1/ High Pressure Laminates Standard colors: Banister Oak, Fusion Maple, Wild Cherry, Frosty White, Natural Almond, or Black 2/ Standard Features - Minimal assembly required - The Sico Eurobed takes up less floor space than a conventional bed - Fold over leg secures mattress when bed is raised, and provides support when bed is lowered - Fully adjustable bed mechanism allows for precise tension adjustments - The Sico Eurobed uses factory calibrated heavy duty springs in each mechanism, unlike other wallbed systems that use a few small springs. - Need not fasten to the floor - pivots off of cabinets on either side of the bed (cabinets must be securely fastened to the wall) - The face panel becomes a finished wall panel when the bed is raised. No bi-fold doors to bother with - The Eurobed has an out-of-sight mechanism and springs. Nothing mechanical is ever seen in normal use
Weiterlesen...
Weiterlesen...
