Quick step - linesse
archiexpo
12. August 2008
The installation of parquet by a specialised parquet tradesman is traditionally done by laying the parquet strips individually. This method of installation produces a very attractive result but is very expensive. This is why three-strip parquet in solid wood was developed. There is however a problem when pre-mounting these three strips, caused by transverse joint across the different strips at the end of each plank. The new Linesse range with innovative Unilink installation tehcnology solves this problem of the transverse joint. UNILINK enables you to install small parquet planks parts even faster while accentuating the natural look of your floor. Moreover, the preassembled underfloor reduces transit sound and yields a solid wood sound. Easy and fast to isntalllWith Unilink floor strips are affixed to the same underfloor panel. It goes without saying much faster to install underfloor panels with 3 floor strips than traditional way of installing the narrow floor strips individually. Just slide and click! Aperfectly natural look You will obtain a floor that has the perfectly natural look of massive parquet, as the floor strips can be moved in relation to one another, without ever having two joints ending in the same palce, as if each piece of parquet has been installed individually. A real wood soundThanks to the 3.5mm pre-mounted underfloor, you not only save installation time but you also obtain a floor that sounds antural when you step on it. The floor sounds more solid.
Weiterlesen...
