PIZ - Innovative cladding system
archiexpo
12. August 2008
PIZ is an innovative cladding system for every kind ot building. PIZ was developed to satisfy the growing needs of the construction market in terms of energy savings and a better external presentation of the structures. The system is designed for new construction and for renovating all buildings. It can be mounted on any surface (reinforced cement, bricks, metal structures, etc). When renovating no special preparation or cleaning of the wall is necessary. Installation is performed with simple mechanical operations that require neither manpower nor special components. The structure is installed by securing light alloy guides on which the panels are fixed. The Panels are mounted in horizontal position. The panel is made by a modified fibre-reinforced cement mortar face coupled with a slab of insulating material. The most common methods are with both heights of the panels and also with planned alternation of height and width.
Weiterlesen...
