archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
One of the primary design parameters for the AGi32 version 2.0 release was to improve the workflow of the software. Make it easier for both veterans and new users to move from one task to another and improve the overall fluidity of the software. The result is a gently modified look (don't panic you old hands) that seasoned users will find immediately comfortable and new users will see as much more intuitive and approachable. Existing AGi32 Users - Must Know Facts about Version 2.0 With the new look and feel under our belts we added some smashing new capabilites to make your work easier and presentations more robust. Consider the interactive orbit capability in Model mode accomplished by simply pressing the shift key while you hold down the mouse wheel. Instantly it is so much easier to see those hidden details. Have you ever longed to navigate in Render mode while calculating, or switch on your textures? Say no more. You can do so seamlessly. You can also stop and start the calculation process at will. Did you ever wish you could visualize ONLY the reflected component of the design? Or, perhaps just direct light? Easy. To make your model building easier: how about the ability to turn CAD created lines into Objects, Rooms, LPD or Statistical areas? Add to this the new Import XREF capability and the Export to DWG (many flavors) option and we have clearly made life easier for you. Now, in the odd event that you are not yet salivating, let's add in the ability to superimpose selected CAD layers, point by point calculations, isolines and whatever else looks cool on your rendered view. You now have a whole new presentation tool to make your work more easily understood by your clients. Smashing! There are many other new features as well, read on and imagine how 2008 will be more productive!
Weiterlesen...
Weiterlesen...
