Metabo 5378 bandsaw bottom wheel out of round
Bardley
8. September 2025
Hapert,
Hi all,
I recently bought a metabo 5378 type B bandsaw, put new tires and new blade. The bottom wheel seems to be out of round as the blade vibrates forwards and backwards. When the wheels are spun with the motor off, there is a distinct noise of the blade tightening and loosening.
Is it possible to fix this wheel? And if not, where can I find a replacement bottom wheel?
Appreciate any advice
Brad
Bardley
8. September 2025
Hapert,
It is the driven wheel which is directly taper locked to the motor drive shaft. The rotation is smooth and no play on the motor bearing. The wheel is slightly oval which is causing the forward and backwards drift of the blade.
