Leaf Indoor / Outdoor Shower
archiexpo
12. August 2008
The Leaf Shower is perfect for indoors or outdoors. The design was inspired by the humble Australian gumleaf and mimicked beautifully in stainless steel plate, with tempered 10mm glass inset panels to prevent splashing outside the cubicle. The perfect addtion to an outdoor hot tub, or courtyard and can be plumbed to chilled water as well as standard hot / cold plumbing outlets. The shower measures 1000mm x 1000mm as the base model and also offered as 1200mm x 1200 size. The handle is designed to run along the edge of one of the leaf shapes on the hinged door, and once again diamond polished. The unit is flatpacked and is quickly assembled. The model can be customised to suit your dimensions. Simply fill in the order form and we will then send you a formal quote which includes freight, insurances and taxes. Please request a brochure to be posted to you to browse through our range of Exclusively Yours bathroom products.
Weiterlesen...
