archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The real breakthroughs in technology are those where the benefits are there for all to see and the technology is not. Thermoglance is one of these. Glass, which is per se a prestigious furnishing material, has now become a heating panel as well.A veritable revolution, because until now radiators – classic, modern or unconventional – were always made of metal. The most high-tech and well-furnished apartments can now be heated with elegant glass elements, whose transparency and physical appearance will improve the aesthetics of the room.Thermal radiation, or infrared radiation, heats objects andpeople regardless of the surrounding air. This means that a veryhomogeneous distribution of heat is obtained, just like thesun's heat.This system offers maximum heating comfort with a pleasantsense of warmth. Furthermore, efficiency is close to 100%, sinceheat is formed in the same point where it is used.Aesthetics. Transparency and compact features make this panel a must-have when an aesthetic, albeit space-saving effect is neededand where precious surfaces need to be highlighted. Easy cleaning and hygiene. Flat surfaces are the easiest to clean. Added to this, convection currents are reduced to a minimumwhich means that dust and therefore allergies are almost eliminated.Easy installation. Either floor-mounted or wall-mounted with elegant supports, all that a Thermoglance panel needs is an electricpower socket. An indicator light shows if it is working.Silent and reliable. The nature of a heat generator at the solid state, without liquids or moving parts, practically eliminates noiseand reduces the number of breakdowns to almost zero.
Weiterlesen...
Weiterlesen...
