archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Electronic safe Code locking (4 to 6 digits) or card locking system Technical specifications Locked for 15 mn after 4 failed attempts Opening control Power : 4x1.5 – LR6 (AA) batteries (supplied) Low battery alert function 20 mm diameter two bolts lock 2-mm steel unit, 4-mm steel door Mounting system : 2 points on rear and 2 on base External dimensions: L.430 x H.230 x D. 390 mm Internal dimensions: L.420 x H.226 x D. 305 mm
Weiterlesen...
Weiterlesen...
