archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Zip ChillTap for chilled filtered water at your fingertips - the perfect choice to replace expensive bottled water in your home.Zip ChillTap sits neat on the sink with an attractive swivel head tap head that can moved out of the way when not in use. The chiller unit and sub micron filters sits out-of-sight under the bench. Nothing could be simpler. No more bottles of water, no filtered water jugs to top up.All Zip drinkng systems for the home come standard with sub micron filtration for refreshing, better-tasting water and additional piece of mind to protect your family against floating particulates and micro-organisms. Zip ChillTap is the perfect choice for any home for chilled filtered water on tap.
Weiterlesen...
Weiterlesen...
