Wooden Gazebos
archiexpo
12. August 2008
Open-air gazebos - Plantago, Calluna, Bellis, Louvre, Vera, Malva, Gata- Airy and light construction, ideal as garden outdoor rest place;- Design which provides the openness for the spa as well as the right amount of privacy; - Optional multi-purpose bar fitted on the third wall (available for small gazebos);- A perplex skylight on the roof top;- Two dimensions available for Plantago, Calluna, Bellis: 3,16 x 3,16 x 2,76 m (external dimensions) 4,04 x 4,04 x 2,98 m (external dimensions)- Available in four colors : Honey, Caoba, Iroko, Roble;- Quick installation system %u2013 assembly time for 2 persons: 2-3 hours (gazebos 3,16 m x 3,16 m) or 5-6 hours (gazebos 4,04 m x 4,04 m). Option 1 - external dimensions 3,16 m x 3,16 m, height 2,76 m; internal dime sions 2,44 m x 2,44 m, height 2,12 m (2,61 m in the gable) Option 2 - external dimensions 4,04 m x 4,04 m, height 2,98 m; internal dim sions 3,35 m x 3,35 m, height 2,12 m (2,83 m in the gable). The cabin structure strengthened with additional pillars On three walls at the bottom there are panel modules with geometric pattern inspired by the rhombus shape On the fourth wall there are only two panel modules on the outside providing access to the cabinA perspex cupola on the roof top Assembly time for two persons is about 2-3 hours Optional bar (3,16 m x 3,16 m) - panel modules on two walls; multi-purpose bar fitted on the third; counter width - 0,35 m; includes 3 bar stools that may be put outside the bar; fourth wall open
Weiterlesen...
