archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Its timeless design permits simple application in a range of projects. The strong geometrical design earns it's place in corridors, meeting rooms and other public areas. Holon is supplied with a variety of light sources such as halogen lamps and discharge lamps. Holon has been designed for rooms that embrace its language of form but do not require an adjustable luminaire head. Holon is a surface-mounted spotlight that is easy to install, featuring an integrated electronic ballast and a language of form which resembles that of the Xharon projector spotlight. The reflectors, which are easy to replace, are highly efficient and suitable for reflector-free lamps, such as QT12-ax and HIT-TC-CE. All models are equipped with an anti-glare ring as well as a filter holder for 3 optional filters. Holor offers you a versatile tool for your lighting design. In 1987, Kreon designed what was to become an icon in architectural lighting. Kreon merged architecture and lighting to a new, essential and timeless design language. Where integrated light is part of every surface in space, the original Up-Side-Down concept became the general and leading translation. Nowadays, this language is, more then ever, indispensible in every lighting design. For that reason, Kreon still extends its range with more innovative and purified design.
Weiterlesen...
Weiterlesen...
