archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
* Free of DIP switch adjustment: Every detector has its own address-code, and transmits it automatically to the receiver, upon its battery connected. * 100 meters transmission range. * Low current consumption: Two years operation with a standard 9V battery * Battery economy mode: Allows alert transmission only if no detection occurred in the previous 5 Minutes. * Transmitted data: Alarm, Tamper switch, Low-battery, "Signs-of-life" for supervision. * Selectable P.I.R. detection sensitivity. * Wide-angle (120°) filed-of-view. * Interchangeable lens for any application. * Auto temperature compensation. * Automatic adaptation to background noise. * Switchable LED indicator. * Extremely reliable & Highly immune to false alarms. * A/D signal analyzer. * Powerful microprocessor controlled. * SPC - Smart Processing Controller. * High level of RFI/EMI immunity. * PIR sensor protective sleeve. * Internal electronic unit protective cover. * Vertical adjustment. * Wall, ceiling or corner mounting.
Weiterlesen...
Weiterlesen...
