Wire Mesh Cable Trays and CombiRack System
archiexpo
12. August 2008
ProblemsThe problem of "spaghetti"The absence of three-dimensional cable organization results in cable "spaghetti" – huge bunch of cables, tangled with each other. When this occurs, new cable cannot be laid because it is impossible to pull out “dead” cable from the "spaghetti". Cable trays begin to sag under the load of cables, which results in faulty equipment operation. Example: Telephone communications node. Rack with data communication equipment. Cables, connecting cross panels and equipment, are laid on top. From time to time contact breaks, and the connection between two points is lost. When this happens, it is impossible to find or remove the faulty cable because it difficult to locate the defective cable within the mass of tangled cables. In such instances, new cable is often laid between the two points, but the old, defective cable is left inside. Over the course of time, this cable "spaghetti" results in 80% of "dead" cables being left in place, while the total quantity of cables increases. Consequently, cable tray supports cannot carry the increasing load and additional supports must be added, sometimes in the form of something such as common boards. Finally, no space is left under the ceiling because cable bundles are laid on one level.SolutionThe Defem System makes it possible to organize cable in trays, which are mounted at different levels. Multi-level cable tray organization allows you to sort and organize the cable bundles from the very beginning. If it becomes necessary to remove a "dead" cable, it can be easily changed for a new one, because it will not be tangled or buried in a huge cable mass, but conveniently located in a single small bundle.The advantages of three-dimensional cable organization based on the Defem system: Flexibility and limitless variations of the system configuration. In complicated mounting conditions, when cable needs to be routed around obstacles, it can ascend or descend from one level to another. The Defem system makes it possible to create different three-dimensional constructions in order to find the best solution. Potential for full system modernization. Using the Defem system allows you to mount new racks, connect old trays with new ones, and make branches that stem from the trays. Three-dimensional cable organization makes it easy to change cables that have become disconnected because they are laid on different levels, thus providing easy access to each cable and the system as a whole. Easy access to the cables. Cables are laid on different levels so they will not cross and become tangled with each other.
Weiterlesen...
