archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Wide slabs are ideal for constructing load-bearing concrete floors.They can be made in any desired shape with a thickness up to 7 cm, and they form the structural and visual bottom surface of a concrete floor.The wide slabs are fitted with bottom reinforcement and have a smooth, flat bottom surface.After the wide slabs are installed, the utility wiring, cables and pipes are fitted and the top reinforcement is installed. Finally, concrete is poured on top of the panels to achieve the desired floor thickness. The result is a solid concrete floor that provides perfect load distribution.Kerkstoel wide slabs are reinforced concrete floor panels that comply with:- the PTV 202 Probeton BENOR specifications for Belgium;- the KOMO specifications;- certification with product certificate number K2188/95 and the ISO 9001 standards. ShapeWide slabs are extremely adaptable, and they follow the design contours precisely. Every space can be covered perfectly withmade-to-measure wide slabs. This saves a lot of time on the job site and considerably reduces the amount of material required.ReinforcementThe full bottom reinforcement is already incorporated in the wide slabs. As a result, all you have to do is install them. Beams can be created in the floor, and openings can be formed.Built-in partsAll built-in parts are fitted in the right place in advance. Provisions for electrical, sanitary, air-conditioning and heating services can be built in without any problems.DurabilityKerkstoel wide slabs are produced in a professional manner and meet the most stringent standards:- optimum resistance to environmental effects- optimum fire resistanceFinishingThe large surface area of the panels minimises the number of joints.The smooth frame surface also provides an ideal substrate for spray plastering. The end result is a solid, monolithic floor that provides good sound isolation and perfect distribution of floor loading. Wide slabs give you an ideal solution for fast,easy, and sturdy construction.
Weiterlesen...
Weiterlesen...
