Hello
nice to read that you have one problem less.
We have a PC between the CNC PC and our rest PC network. They are connected by arcnet. This PC runs under DOS and is connected to the rest by a novell network
. Alphacam only runs on a Win 2000 PC at a working desk in the office.
As far as I know BP 15 run under a UNIX OS. It was quite usually in industrial PC's because it's code is open and could easyly by customized. BUT DON'T format the disk. I Think it will cause a lot of problems.
Connecting an old CNC System to newer IT is not so easy.
First of all you should see that the CNC runs well with the PC installed at the CNC.
Weeke and Homag CNC are usually programmed with the homag woodwop programm. BP 15 was as far as I know delivered with woodwop 2.5 running under DOS. A lot of BP 15'th were updated to 4.5 ( running under WIN 95 and later versions). Which Version is installed by your BP 15 ?
The rest is more or less a special software problem. You should look for real IT crack.
For using alphacam with the BP 15 you need to tell alpacam some parameters about your BP 15. For further information it couldn't be a mistake to contact alphacam.
Licom Systems GmbH, Homepage it's in German but perhaps they can help you. Just try to contact in English. I had several times contact with them at exhibitions like Ligna. They were very polite .
Or try the internatinal site at
Planit. There seems to be a alphacam forum
Or just ask here at woodworker.
Perhaps there are some other users who can help.
