archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
1. Waterproof material: Silicone material which features anti-oxidation, anti-UV radiation, working temperature (- 80~300°C). high flexibility, high transparence, flame proof and environmental friendliness.2. IP ratio: IP67 3. Options to fix the waterproof strip:Option A: with 3M glue at the back of silicone tube; Option B: with silicone clips;4. Easy DIY waterproof process with waterproof accessories offered in free of charge.5. Transparent waterproof connectors atone end of waterproof strips or at both ends of waterproof strips, either of which is available;6. This waterproof mode is available for the following series: 1 ) GL fa -Series2) OL-FB- * Series3) GL-DFB- * Series4) GL-FB- -'-24 Series5) GL-HFA- - Series6) GL-GB-RGB Series7. Standard Accessories per reel (5 meter): a pair of waterproof connector, 1 pes glue( 10ML) ,10 pes clips, 20 pes screw( if use 3M adhesive tape back,we will not provide the clip and screw), 4 pes end cap;
Weiterlesen...
Weiterlesen...
