wall-mounted reversible air conditioner
archiexpo
12. August 2008
Never has technology gone so far to provide optimum comfort and simplify the installation process. With its refined and fluid lines, the SX DCI brings together the new aesthetic trends. Its "High Tech" control panel and exceptional slimness mean that it can blend in harmoniously with all décor styles, and has a rare degree of discretion and elegance that satisfy the new expectations in terms of living habitats and the tertiary sector. The latest DC INVERTER technology, in combination with the use of the eco-friendly fluid R410A (that preserves the environment) make for optimum efficiency (class A energy label) and exceptional performance levels. (Operates in hot mode down to -15 °C). Its flexibility and user friendliness, ability to retain a constant temperature, broad operating range and extremely silent running make it an exceptional device. * Perfect comfort, unequalled unobtrusiveness, great accuracy in maintaining the desired temperature and controlling air quality. * Compatible with AIRCONET regulation (SX 24/30 DCI). * R410A %u201Dgreen%u201D fluid. * Optimal efficiency: Class A energy label (depending on models). * Heating mode operation down to outdoor temperatures of -15° C. * Optimal temperature regulation. * Electronic regulation and programming. * Dual automatic treat air sweeping. * Fluid pre-charged at the factory for up to 20 m pipe lengths (depending on models). * Low wall or ceiling mounting. * Possibility of air conditioning two separate rooms with a single unit.
Weiterlesen...
