archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Our "Classique" range of wall-mounted benches was specially developed to be put on any type of walls and to facilitate the cleaning in changing rooms environments. These benches are provided with GS colour coat-rail and can be accompanied (or not) with racks.Information and measurements :Frames in square or rectangular steel tube, coated in 100% stove-enamelled polyester resin. The frames consist of 30mm* x 30mm vertical supports; bench frames 30mm* x 30mm and 35mm x 15mm. Rear frames screwed to floor and wall; frame wall welded onto the frames. The frames support one coat hook rail in GS. Bench seat height 44cm; Height of coat-hook rails 155cm. Lengths from 1.20m to 3m, in 15cm increments. Screws and wall plugs supplied. Dimensions: Height 175cm; Width 34 cm
Weiterlesen...
Weiterlesen...
