archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Range of surface mounted fixtures conceived to host halogen QR111, metal halides CDM-R 111 and LED light sources.An urban style realized by using a common material like carpentry steel; the material is used in its natural state: row; the “scars” owing to the carpentry processing of cutting and grinding are not concealed but enhanced and protected by transparent varnish. What is commonly considered as a blemish is transformed into an interesting superficial texture. The singular match with the bright internal colours magenta, white and acid green, creates an appealing contrast, thus resulting into a high emotional impact system, particularly suitable for the retail and leisure markets, as well as for modern residential spaces.Sources: halogen QR111, metal halides CDM-R 111, LED.Emission: direct. Manufacturing features: drawn row material; outside transparent varnish and inside high temperature resistant varnish, available in the colours magenta, acid green and white. Wiring: electronic.Dimensions: X 150mm - h150mm | 150mm X 150mm - h220mm | 150mm X 150mm - h290mm.Classifications: IP20, F, Class I.
Weiterlesen...
Weiterlesen...
