archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Type S, created to support big measures at low costs, is ellipsoidal shaped in form of "airplane wing" and with a modern line. Blades 22-27-34-40-47-60 cm width, elliptical profile manufactured from pre- painted aluminium sheet 0,8-1,0-1,2 mm thick, reinforced inside by extruded aluminium "I" section. Shaped end blocks fit inside the louvre skin, manufactured from nylon or die-cast aluminium. The end blocks retain the "I" reinforcing position. Extremely high deflection resistance. Maximum height of one louvre 3 metres for blades 22 cm, 4 metres for blades 34 and 40 cm, 6 metres for 47 cm, 8 metres for 60 cm. Frames: natural extruded anodized aluminium, with more sections depending on the dimension of the blade and according to aesthetic needs. External connecting-bar in natural extruded anodized aluminium on bronze washers and inox nuts. Controls: teleflex type manual control, with reducer or electrical linear action. Colours: standard colours are white ral 9010 and silver ral 9006. We can supply all ral colours upon request
Weiterlesen...
Weiterlesen...
