Tulikivi Zevio - Lightweight Fireplace
archiexpo
12. August 2008
The rounded, light-weight Zevio is a compact design piece which is easily installed in a corner or, using a flue connection located above the fireplace, even in the middle of the room. The grooved, naturally rough Tulikivi Sky and the smooth Tulikivi Blue stone types give an elegant finish to the fireplace and accentuate its large door beautifully. Installed in the middle of the room, the surprise feature of the rounded Zevio, its column-shaped rear and metal ledges, gives character and strength to the otherwise soft appearance of the fireplace.EXTERNAL DIMENSIONS Height: 1340 mm Width: 650 mm Depth: 575 mm Weight: 555 kg
Weiterlesen...
