Triaqua Reverse Cycle Chiller-innovations in air source heat pumps
archiexpo
12. August 2008
One of the more notable innovations in air-source heat pumps is called a Reverse Cycle Chiller (RCC). It offers the advantages of allowing the homeowner to choose from a wide variety of heating and cooling distribution systems, from radiant floor systems to forced air systems with multiple zones. Italso offers the potential for lower winter electric bills and hotter air out of the supply vents for greater comfort. In this innovation, the people enjoy winter heating and summer cooling.An RCC is especially economical for all-electric homes or in areas where natural gas is not available. Depending on other fuel rates, it may even be the least expensive heating option over all of the remaining heating fuel choices.The system consists of a standard 12 SEER, single speed, air-source heat pump, sized to the heating load rather than the usual smaller summer cooling load. The heat pump is connected to a large, heavily insulated tank of water that the heat pump heats or cools, depending on the season of the year. Most systems will use a fan coil with ducts, employing the stored water to heat or cool the air and distribute it to the house. During the heating season, the hot water can be distributed through a radiant floor system.The RCC eliminates one of the biggest complaints about air source heat pumps, which is the periodic blowing of cool air during their defrost cycle and during the initial start of the heating cycle as the distribution ducts warm up. The RCC system solves these problems by using the stored heat in the water tank to defrost the cooling coils, rather than the room air. For Triaqua reverse cycle air source heat pump with domestic hot water. Please refer to www.china-heatpump.com
Weiterlesen...
