archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
KARMA is the exclusive glass covering tile created by Trend to enhance the colour depth through vivid light effects.Inspired by Gothic cathedral windows, KARMA combines tradition with innovation thanks to a silver foil on the plate rear which gives the material a particularly deep effect. The hand cut glass tiles are available in different sizes: from 2x2 cm to 48x96 cm, particularly suitable to cover big surfaces such as counter tops or walls, while reducing the number of the joints. The wide colour range and the intentional lack of colour homogeneity makes KARMA the best solution to create original decorative combinations: the total look of the surface will be pleasantly uneven. The possibility to use the coloured filler MAKE UP in any material laying adds further possibilities of customization. Thanks to its resistance to chemical agents, to thermal shocks and since it doesn't absorb water, Karma is suitable for any indoor and outdoor covering. Standard sizes: 2 x 2 cm; 2 x 4 cm (aligned or staggered joint); 4 x 8 cm; 4 x 4 cm; 4x 8 cm (aligned or staggered joint); 8 x 24 cm, 15 x 30 cm; 12 x 48 cm; 48 x 96 cm Colour range: 28 different colours.
Weiterlesen...
Weiterlesen...
