TR-2 - Waterproof lighting
archiexpo
12. August 2008
Its 5 mm. acrylic body gives it extraordinary protection against impacts, giving it an IK10 protection rating. The lasing is perfectly suited to dusty or wet conditions. Thanks to its excellent IP protection rating of 68 and allows it to be submerged to up to 2 meters. This light fixture unites waterproofing, strenght and design. It´s the perfect solution to illuminate spaces that require a high quality fixture, that is able to stand the worst conditions, which makes it ideal for its use in: industrial, cooking hoods, greenhouses, fountains, pools, paint booths, direct tool lighting (resists direct hits,) outdoor lighting. Available in high temperature version. Light fitting: Acrylic 5 mm End caps: Nickel-plated Zamak Reflector: Glossy aluminium Working temperature: From +5ºC to +25ºC Accesories: 2 galvanised clamps
Weiterlesen...
