Tokpo 11 Release: Topography, cadastral and 3D models
archiexpo
12. August 2008
New main functionsA new version that represents not only an evolution of Topko but also changes the way theuser works and tries to solve any kind of topographic or cadastral problem. The newcommands and functions make it a complete tool, with a great care for details, able tofollow the development of a work in every phase: from the importation of field data to thegeneration of drawings and final reports.Field data recorder and topographic instrumentsThe commands for the connection with the instruments and for the reading of the dataformats of the different instruments have been put together in a common managementmore direct and easier to use, allowing to perform all the operations in a singlepassage.Generating a 3D drawing from parametric objectsBy a new command it is possible to complete the topographic drawing by creating new drawing entities according to elements surveyed only partially. Starting from a reference polyline it is possible to create quickly ditches, walls, sidewalks, slopes, by using parametric objects; the sizes can be either set for the whole polyline or interpolated by segments. The tool can generate 3D lines, break lines and triangulate directly the surfaces, thus reducing drastically the time necessary for the survey to bereturned.
Weiterlesen...
