archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
New main functions A new version that represents not only an evolution of Topko but also changes the way the user works and tries to solve any kind of topographic or cadastral problem. The new commands and functions make it a complete tool, with a great care for details, able to follow the development of a work in every phase: from the importation of field data to the generation of drawings and final reports. Field data recorder and topographic instruments The commands for the connection with the instruments and for the reading of the data formats of the different instruments have been put together in a common management more direct and easier to use, allowing to perform all the operations in a single passage. Generating a 3D drawing from parametric objects By a new command it is possible to complete the topographic drawing by creating new drawing entities according to elements surveyed only partially. Starting from a reference polyline it is possible to create quickly ditches, walls, sidewalks, slopes, by using parametric objects; the sizes can be either set for the whole polyline or interpolated by segments. The tool can generate 3D lines, break lines and triangulate directly the surfaces, thus reducing drastically the time necessary for the survey to be returned.
Weiterlesen...
Weiterlesen...
