The Twin Tile A revolutionary roofing panel
archiexpo
12. August 2008
The “ Twin Tile ” is a double plated roofing panel, constructed of two alu-zinc steel-plates with a thickness of 0,3 mm . The outer plates are pressed together with a middle layer of polymer foil. They have their powder layer applied by an environmentally safe method. Thanks to the technical know-how of one of the world's largest powder producers, our tiles are subject to a policy of a consistent quality and innovation. So we offer these extra advantages: • Consistent quality • Environment-friendly coating process (free of heavy metals) • UV-resistant powder coating, meeting the highest standards • Scratch resistant • Powder-layer application according to ISO 9001 The “ Twin Tile ” is applicable for new construction and re-roofing. The minimum accepted pitch is 5° (9%). Our expanded assortment of special fittings and accessories provide a solution for every roof. You can count on an attractive and stylish appearance, an excellent imitation of a traditional roof covered with clay tiles. Because of the numerous advantages of our “ Twin Tile ” you can finally be sure of the roof over your head: • High weather resistance • Durable • Noise-absorption due to double construction • Self-cleaning • Better insulation and less condensation • Strong • Simple and fast installation • Only a light sub-structure required • Ease of handling and transport A roof covered with “ Twin Tile ” requires only a minimum level of maintenance and guarantees a long live. Therefore we offer you a 30-year ‘watertight' guarantee!
Weiterlesen...
