THE OPTIFIRE 800 green
archiexpo
12. August 2008
THE OPTIFIRE 800 green brilliantly succeed the air tightness tests and get the label “Approved Passive House”!As it benefits from all the advantages of Bodart & Gonay's new generation of wood-burning fireplaces, as do the Infire 800 Green and the Design 800 Green, the OPTIFIRE 800 Green is characterised by exceptional ecological performance, emitting less than 0.02% de CO, which is considerably below the European standards which will come into force in 2012!In addition, these exceptional results are achieved without the use of expensive and/or energy-consuming devices, such as catalysts, electrical resistances or even particle filters.Furthermore, this total combustion guarantees very high efficiency, glass which is always clean and a flue which soots up very little.Because the OPTIFIRE 800 Green can draw combustion air directly from outside, it is independent of the mechanical air circulation systems in the house. It is consequently perfectly airtight and has been positively tested, in real configuration, by an approved organization, the Scientific and Technical Center of the Construction Sector.It can then be integrated without problem in a passive or low energy house and has the label « Approved Passive House”.By choosing an OPTIFIRE 800 Green, you are opting for a high technology appliance while making a gesture to save the planet!Available in two finishes: traditional metal front or glass front (black screen).
Weiterlesen...
