archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The movable pool floor owes its strength of character to the subtle interplay of wood and steel, design and engineering. It helps to create a practical, aesthetically appealing and, above all, safer living environment.Intelligent space managementBlends in with your decoration scheme.1 - StructureThe structure is made of rectangular tubes that are assembled and welded in the factory. These elements are then assembled on site and bolted together to form a framework. The finishing covering is then attached to the assembled structure. This process allows the equipment to be transported and assembled on-site more easily. 2 - Mounting points The mounting points, which are linked to the drive system by cables and pulleys, support and guide the cables along the path between the supports and the drive system. 3 - Cable supportsThe cable supports fitted underneath the structure, hold the cables in position along the inside wall of the pool, and allow the level to be adjusted when the movable floor is installed. 4 - StabilisersThe stabilisers positioned at intervals along the length of the structure are used to adjust and centre the movable floor.They prevent the floor from swinging from side to side when in a raised or intermediate position. They form the interface between the drive system and the movable floor. 5 - Drive systemThe drive system uses a worm gear and sealed gearbox to pull the cables to which the floor is attached. The cables guide the path followed by the anchor disk as it moves horizontally. The length of the worm gear matches the depth of the pool up to the coping boards.Sealed limit switches stop the floor's movement when it reaches the surface or the bottom of the pool. The drive system is controlled by a control unit that enables the platform to be stopped at the desired height.6 - Adjustable feetThe feet located at intervals below the structure prevent vertical oscillation and stabilise the floor when the system is lowered to the bottom of the floor.7 - Inspection hatchAn inspection hatch provides access for a cleaning robot to clean the pool bottom, or to allow servicing by a maintenance technician.
Weiterlesen...
Weiterlesen...
