The Fusion Handrail System
archiexpo
12. August 2008
Fusion is a revolutionary new stair balustrading system by Richard Burbidge Limited, produced from a combination of timber, metal and ABS plastic components. Why revolutionary? Fusion will take around 50% less time to install and finish than traditional timber balustrading. The method of installation is extremely straightforward, for example, a typical straight flight in timber balustrading requires approximately 125 saw cuts, Fusion requires just seven Plus due to the nature of installation, the cuts are hidden by the fixing connectors so they dont even need to be 100% accurate. Timber elements are completely pre-finished in clear varnish, and the metal and ABS components are ready to fit. Fusion is suitable for both new build or refurbishment projects and is approved to UK Building Regulations. The styling of Fusion is contemporary with a simple, minimalist look. The traditional turned newel is replaced by a shorter length of the handrail material, the rails and newels are connected using a number of alloy handrail connecting brackets, which allow almost every configuration to be created. The balusters are tubular in Chrome or Gold effect metal or match the timber handrail with timber balusters, pre-cut to length. The Balusters are then fixed using ABS baluster fixing brackets that cleverly flex to adapt to a range of different pitch angles.
Weiterlesen...
