The concept of the Noétech
archiexpo
12. August 2008
The concept of the Noétech series is based on boards of standard cross sections, like 60/180 or 60/240mm. Boards are layered, offset and screwed to form the posts, rafters and tie-beams. The great second moment of area obtained provides a high bending strength to the members. Bracings are built using the same cross-section to keep a homogeneous appearance. The articulations of the frame are rigid to increase the stiffness and to reduce evermore the amount of wood used. Purlins are end-jointed to form continuous beams, which are statically more efficient. Overhangs can be created easily by stretching the rafters.
Weiterlesen...
