archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Claro is an acoustically transparent coating with the classic appearance of drywall or plaster, and yet incorporates superb sound absorbing properties on acoustic panels. DESCRIPTION Claro is a coated finish that is specifically formulated to provide acoustical transparency and exhibits a very white flat painted gypsum board/plaster appearance. The finish is applied to both the panel face and edges. Specified as CSW-100 for a standard white. Claro can also be custom coloured to match Pantone and other type paint chips. DESIGN CONSIDERATIONS Maximum Panel Size: 48" x 72" (1220mm x 1830mm) is largest size recommended by Decoustics. Panels larger than this are susceptible to coating damage during handling and installation. Consult Decoustics for larger size availability for specific applications. MAINTENANCE Can be cleaned using water or recommended cleaners. Refer to "Claro Cleaning & Maintenance Instructions" for specific data. Do not paint face of panel. Painting will significantly reduce acoustical absorption, and may also affect panel finish integrity and fire flamespread performance. The Claro finish itself cannot be field applied. The finish is factory applied in a strictly controlled environment and method, however, small scratches or blemishes can be touched up in the field. Note: Only handle panels wearing clean, lightweight, white gloves during installation. Follow manufacturer's printed instructions for installation as well as field cutting of panels. HANDLING & CLEANING INSTRUCTIONS Panels must only be handled by persons wearing clean light-weight gloves. It is very important that personnel working with panel hardware, HVAC, electrical, sprinkler, or similar equipment, do not handle the panels before putting the clean lightweight gloves on. To prevent overall soil, vacuum with a light brush attachment, or brush lightly to remove dust and grime. For dirty marks and hand-prints, use a white eraser (Staedtler Mars Plastic or Staples Technical eraser), and erase the marks. For more stubborn stains, use a cleaner such as a clear, streak free, foaming window cleaner (eg. “Windex”), to lift the stains from the surface. Experiment first with an area that is not too prominent, on one panel, to ensure cleaner is effective before treating all soiled panels. Be sure to blot the area with a clean dry cloth to remove as much water or cleaner as possible, so the area will dry faster and cleaner. DO NOT APPLY PAINT TO THE FACE OF THE PANEL. CLARO – INDOOR CLIMATE STORAGE On-site storage shall be such as to assure that all panels and associated materials are protected from damage, and storage area is climatically controlled to normal operational levels. INSTALLATION Prior to panel installation, the site must be free of all wet and dusty trades and the climatic conditions stabilized to normal operational levels. Panels shall be allowed to stabilize on site 24 hours prior to installation. NORMAL OPERATIONAL LEVELS Typical Indoor Comfort Standards state a temperature range of 20ºC - 27ºC (68ºF - 81ºF), and a relative humidity of less than 60%. These would be considered as normal operational levels. RECOMMENDED USES As a finish for ceiling panels. Suitable for flat, shaped and 2-dimensional pre-curved panels. Note: There are some radii limitations for pre-curved panels. Consult Decoustics for specific data. Available with factory and field installed custom edge returns. Consult factory for details. FEATURES AND ADVANTAGES Provides excellent light reflectance of 92% for standard white CSW-100. Provides Class A flame spread (less than 25) for an assembled (composite) panel when tested to ASTM E84. Provides excellent acoustical absorption: Tested in accordance with ASTM C423 yields an NRC 0.90 and an SAA of 0.87 for Type E400 Mounting per ASTM E795, and NRC 0.80 for TYPE A Mounting per ASTM E795.
Weiterlesen...
Weiterlesen...
