archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The foil SR41DBF5 is ideal for the Thermo-Acustic Insulation of walls. Its composed by two sheets of aluminium on both sides, with two layers of stanched air bubbles, hermetically closed and a layer of foam inside. This products thickness is only 12mm and works in a temperature range of -40ºC to +80ºC.
Weiterlesen...
Weiterlesen...
