archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The Terminal Fold Away is designed to distribute electric power and services in general, including water, compressed air, TV signals, etc.The terminal structure is built entirely from AISI 304 stainless steel and then coated with polyurethane powder.A nodular cast iron cover attached to the upper part of the terminal is available in both a normal or fill-in version which means it can be perfectly matched with any pavement.The terminal is equipped with various services, according to requirements, and is completely buried.It can be extracted by using a hand crank or a simple battery-powered drill.As a result, pedestrians can walk on and heavy vehicles can travel through this area in complete safety.The Terminal Fold Away can be used in various locations such as town squares, market areas, exhibition pavilions, condominiums or for general applications in the industrial sector.The Terminal Fold Away is indispensable in all areas that require a temporary hook-up to specific systems, which can then be removed, leaving the area in its original condition..Last, but not least, the Terminal Fold Away is completely environmentally-friendly, shockproof and protected against vandalism.
Weiterlesen...
Weiterlesen...
