Tansun's new IP65 rated variable controllers
archiexpo
12. August 2008
Tansun has launched a range of IP65 rated variable controllers, which can be permanently installed either inside or outside for year-round use. Tansun has launched a range of IP65 rated variable controllers, which can be permanently installed either inside or outside for year-round use. Tansun's 'soft start' controllers are available in 2kW, 4kW and 6kW power options and can be used through a distribution board for extra zoning of single quartz infrared heaters or groups of heaters. The soft start function will increase the life of your heater lamp by up to 30%.The heat output can be varied from 30-100% using either the main control panel or a remote control handset, ensuring maximum user comfort and energy savings.These controllers can be used with any quartz heating product, making them ideal for retro-fit as well as future heating schemes.For further information please contact Tansun on +44 (0) 121 580 6200/17.
Weiterlesen...
