Swimming Pool Heater Horizontal
archiexpo
12. August 2008
Features of product of swimming pool heater/swimming pool heat pump: 1) Our product of swimming pool heat pump can be widely used the constant temperature swimming pool and sauna constant hot water system. 2)Which supply hot water to heat the pool or provide the hot water. 3)Type: Side discharge swimming pool heat pump and Top discharge swimming pool heat pump. 4)Capacity ranges from: 3.5kw, 4.2kw, 7kw, 9kw, 12kw, 15kw & 20kw for side discharge swimming pool heat pump. 4.2KW, 5.3KW, 8KW, 12KW for top discharge swimming pool heat pump. 5)Gas: R407C mainly. 6)With Titanium Exchanger with long operating life. 7)Galvanized panel which is rustless. 8)With CE approval for swimming pool heat pump. 9)With RoHS compliance for swimming pool heat pump.
Weiterlesen...
