Starline Roldeck : the customized quality pool cover
archiexpo
12. August 2008
The Starline Roldeck is always made to the customers requirements. Its well-considered construction and design means it opens and closes smoothly, without any noise and with just the click on a button. The slats are made from hard PVC or even Polycarbonate. The end caps are finished in the same colour as the slats and are ultrasonically welded, guaranteeing total watertightness. A Starline Roldeck swimming pool cover really finishes your pool. Not only does it look great, it keeps your pool water clean, saves energy and stops dirt of entering the pool. Moreover, it creates a safer swimming environment for children and pets to be near the pool, especially when equipped with a Starline child-safety lock. Starline has been the leading supplier of made to measure Roldeck slatted pool covers for well over 25 years. The system consists of very strong plastic slats which rest on the water's surface. When automatically opened and closed, the slats are rolled around a stainless steel roller. Advanced technology and a special Roldeck cave in the pool even enable the Starline Roldeck to be installed entirely submerged. Starline has its own range of in-roller motors; A unique reliable drive-system , which ensures that both the motor and the winding mechanism can be entirely integrated into the swimming pool and stored hidden. Thanks to its many installation options, the Starline Roldeck is suitable for all types and sizes of swimming pools. Whether they be fibreglass, concrete, tiled or liner pools: a Starline Roldeck is by far the most ideal solution for protecting your swimming pool water and creating a safe swimming environment! If there is a wall along the short side of the swimming pool, the Roldeck can be installed against this wall. The easiest and fastest way to cover your pool; new or existing!
Weiterlesen...
