Standard - ftv
archiexpo
12. August 2008
Panels of the Trimoterm FTV family are produced in accordance with the patented production process by the use of lamella technique made of uninflammable mineral wool (A1 in accordance with DIN 4102,EN 1182), which assures the best utilisation of compression, tensile and shear properties of the core. Simultaneously they assure optimal thermal and fire characteristics. The face of a panel is made of hot galvanised (275g/m2) and painted sheet metal in standard thickness of 0.6 mm and 0.5 mm, which gives a panel strong mechanical resistance, durability and aesthetical appearance of a surface. External anti-corrosion protection is adjusted to climate requirements. Use of corrosive-resistant materials is possible under severe conditions. During the production process both faces of sheet metal are compactly glued with the core by a thin layer of adhesive (3) that meets high strength and durability requirements.Advantages:- Strong fire resistance (30 to 180 min)- Good thermal and sound insulation, - High load-bearing capacity, - Water- and air-resistance,- Durability and - Fast and simple assembly.
Weiterlesen...
