archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
A one-piece constructed tub that features double wall insulation to keep the water temperature constant for hours. This particular tub also features a unique combination drain and overflow assembly and a sloped back for comfort. An option for this tub is an airjet system. Features: - Large One-Piece Soaking Tub with Integral Reclining Back - Insulated Double-Wall, Heavy Gage Stainless Steel Construction - Stainless Steel is a Recyclable Metal. - Extended Skirt Conceals Internal Drain Piping - Combination Drain & Overflow - Custom Sizes and Features Can be Fabricated. Please Contact Neo-Metro with Custom Specs & Drawing for Quotation. - Option - Jetting with Heat Maintenance NOTE: Faucet and drain in floor not included Models: - Satin Finish 8972 72-1/2 in Long. 105 Gallons. - Satin Finish 8972-JET with Hydro Massage Jet System Product Specification . . . Tub shall be manufactured with heavy gage, type 304 stainless steel. Construction shall be seamless welded and exposed surfaces shall be polished to a satin finish. The tub features a patented design* of double wall construction and a 60 degree sloped back. The sloped back allows the user to comfortably recline in the tub. The tub shall have a skirt flush to the floor line concealing the internal plumbing. A 2" (51 mm) combination drain and overflow assembly is provided. The tub can be configured with a massage jet system that has an integral temperature maintenance capabilities. Plumbing Specification . . . Drain in the tub floor is positioned in the center. Water drains out to the 2" (51 mm) combination drain and overflow assembly positioned toward the end of the tub. Faucet not provided by Neo-Metro.
Weiterlesen...
Weiterlesen...
