archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Softub® - the portable spa There is nothing more pleasant than relaxing in the swirling water and light steam of a warm spa. Stretched out comfortably, you will truly enjoy the pleasantly massaging water. A sense of well-being and relaxation comes over you naturally. Modell no 300+ Capacity 5-6 Persons Outside Ø 200 cm Inside Ø 170 cm Height: 69 cm Weight empty :78 kg Tub: 45 kg Hydromats ®: 19 kg Thermo-cover: 14 kg Total weight: 1208 kg (filled) Interior illumination: integrated Padding: PolyBondTM Outer covering : LeatherTex® Water quantity: 1130 l Number of jets : 8 Connection for power supply: 220V / 240V 50 Hz, 6A Electric power consumption : 1,4 KW
Weiterlesen...
Weiterlesen...
