archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
functioning of the systemThe temperatures of the swimming pool water (1) and the solar collectors (7) are continuously compared to each other. The controlling system (8) commands the collector pump (6), hat starts functioning if there is enough energy available in the solar collectors. The check valves (9) guarantee that the water flows into the right direction.The pump sends the swimming pool water directly trough the solar collectors. This has following advantages : * The cost price of the installation is reduced while the use of a heat exchanger can be avoided. * Each kind of heat exchange requires a difference in temperature. Because there has been saved on a heat exchange, the collector can provide a higher performance at a lower temperature. If there is no more energy available in the collectors, e.g. after sunset, the pump is switched off.
Weiterlesen...
Weiterlesen...
