SOFT-LAY System: Inter-floor Noiseless Raised floor
archiexpo
12. August 2008
The raised floor is a modular structure and subjected to the normal trample or to particolar radial loads it could have minimal movements that are mainly transferred to the pedestals base of the metallic substructure of the raised floor; the contact between the steel of the substructure's base and the concrete where the raised floor is leaned on, could cause creaking/noise that could be perceived in the rooms where the raised floor system is installed and, through the concrete slab, transmitted to the rooms under the installed raised floor. To solve these kind of problems, avoid this irritating acoustic transmission and to suit the raised floor with the European norms in the field of “Passive acoustic requirements of the buildings”, Newfloors introduces the SOFT-LAY system. SOFT-LAY is a simple element composed by a polymer having a particular structure which, housed between the pedestal base of the metallic substructure and the concrete slab, acts as soundproof pad that “breaks” the “inter-floor” noise's transmission and makes the use of the raised floor system extremely comfortable.SOFT-LAY is the ideal solution to guarantee the minimal acoustic impact of a raised floor, keeping its technical characteristics unaltered.
Weiterlesen...
