archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The smart SL-3131 dual pocket dryer is a stacked version of our SL-31 model. The unit contains two 30-lb capacity tumblers and boasts all the same great features of its single-pocket sister including lower heat input and lower airflow. Benefits Drying Performance: The SL-3131 achieves outstanding drying performance. The unique design with 100% axial airflow allows for optimal drying performance in gas, steam, or electrically heated dryers. Dramatic utility savings are realized without sacrificing dry times. The 55,000 Btu/hr heat input accomplishes what others can only do with higher utility requirements. Compact Footprint: Dimensionally the SL-3131 boasts a smaller footprint resulting in a more efficient use of valuable floor space. Easy To Use Microprocessor Controls: When you drop in a coin or insert a debit card, the SL-3131 then clearly displays and counts down the time remaining. Easy to read graphics are customer friendly and can be programmed to scroll between two different languages. The multi-lingual micro is also self-diagnostic, which means problems are quickly identified and downtime is reduced. Durability: The SL-3131 features a rugged four-wheel support system that parallels the design of larger industrial dryers. Stainless steel tumblers, door hinges and lint screens are impervious to corrosion while heavy-duty doors feature a heat-saving double glass design. Components are 98% front accessible for ease of service.
Weiterlesen...
Weiterlesen...
