archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
His innovative management object, along with an input completely renovated, make it a product of extreme simplicity and concreteness.The program was completely rewritten in a modern development environment by making use of the precious and irreplaceable experience of nearly twenty years of relationships with users.Alongside a traditional way of working allows input completely disconnected from the problems of modeling covering nodes, wires, poles, etc.. Modeling it can be managed entirely on the basis of simple criteria for the algebra of solids. This translates to the user in an easy to use, especially when input sometimes not easy to approach.A very important characteristic, then, is the automatic mesh generation that allows the definition of plates with simple polyline, without the need for artificial discontinuities in correspondence of structural elements. SismiCad 11 will always have the way of finite element are connected together by creating each node where it is needed.It is possible to download a free demo version of SismiCad 11.6 for reinforced concrete, masonry, steel and wood without the need for any registration. To run the first test structure is advisable to follow the guidance on the drop-down menu called Help and Tutor. Nothing else.
Weiterlesen...
Weiterlesen...
