Simple window hinge
archiexpo
12. August 2008
The Roto HG05 Hinge series features 10" and 13" washability versions as well as a 10" egress version and is suitable for most casement and awning window applications (wood, vinyl, aluminum, and fiberglass). They are available in both 7/16" and 1/2" stack height versions, so there is no need for a spacer. The use of high quality materials and manufacturing processes makes this one of the strongest hinge on the market. The hinges are available in powdercoated steel or Stainless Steel versions. Features Each hinge is equipped with Roto's quick disconnect feature that allows for easy snap connection between the sash and frame. With a simple turn of a wrench, the hinge adjusts to compensate for sash sag or window manufacturing variations, up to 3mm (.125"). Additional holes in the hinge arms allow for installation into a bow/bay window and for adding a limiting device. Performance Hinge arms are rounded at the edges to resist binding and the track/slider overlaps by 2.7 mm (0.106") to prevent disengagement. The hinge slider is reinforced with a stainless steel insert for greater rigidity and furnishes a 2mm clearance, eliminating interference with screws. The HG05 hinge is AAMA 904 lifecycle compliant at 125 lbs. on the 13" hinge and at 110 lbs. on the 10" version. Both steel versions are AAMA 907 corrosion compliant at 750 hours for powdercoated and over 1000 hours for stainless steel. The hinges also pass ASTM E1886 and ASTM E1996 hurricane impact testing.
Weiterlesen...
