Shower in brushed stainless steel Inox Square
archiexpo
12. August 2008
Inox Square is a shower in brushed stainless steel, with a 100 mm by 50 mm rectangular shape. Highly contemporary, it will charm anyone who loves pure luxury. The brushed finish softens the stainless steel's colour and natural reflections. A stainless steel structure creates a magnificent contrast of materials with wood or stone and elegantly blends into the atmosphere of contemporary buildings. We have chosen to use 316L grade stainless steel, for its marine and inclement weather resistant properties, which therefore removes any risk of pitting. A measure of the quality which remains our first priority.This shower is equipped with accessories in stainless steel, an extra-slim design shower nozzle 15 or 20 cm diameter. Available in the standard version with 1 faucet, it can be also offered in the hot/cold water version with 2 faucets. An additional foot-rinse tap is a possible option too. Can be easily installed on a terrace or on a lawn.Weight : 22 kgThanks to the installation of a « hot water regulator », thisshower, like all the products of the range, can be easilysupplied with mixed water. The “hot water regulator” is installed either upstreams by means of a branch circuit to the hot/coldwater network (there will be thus outside only a single pipe), or atthe shower base in case a double hot/cold water inlet is already provided for. Water is kept at a constant temperature, regardless of the outdoor temperature.
Weiterlesen...
