archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Hand-sculpted out of clay, the Shasta ceramic table exhibits a simple and minimalistic aesthetic. Withits organic shape, smooth contours and clean lines, this ceramic table serves as a side coffee table aswell as a sculptural element. Designed by Ayala Serfaty, the Shasta table was created in collaborationwith ceramic artist Marcelle Klein. The Shasta table is available in white or black.Weight: 5 kg, 11 lbsPackage Size: 52cm x 52cm x 36cm (H), 20.5” x 20.5 x 14.2” (H)Package Material: Wooden BoxPackage Weight: 15kg, 33 lbsThe Gladis Lounge Chair radiates an ethereal quality enhanced by its hand-stitched details, thus providinga ripple effect, reminiscent of the fluid forms found in nature. The pre-shaped fabric cover isupholstered over ergonomically shaped polyurethane foam, designed for optimal comfort. Set on aswiveling ten-wheeled base – thus allowing natural movement and positioning - Gladis is available in12 colors.Weight: 36 kg - 79.2 lbsPackage Size: 122cm x 110cm x 72cm (H) - 48” x 43.3” x 28.3” (H)Package Material: Wooden BoxPackage Weight: 44kg - 96.8 lbs
Weiterlesen...
Weiterlesen...
