archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Features • Fixed Window and operable skylight for use with thermoplastic and glass glazing • Extra deep (1-3/8") glazing rabbets to allow for thermal expansion of the glazing material Glazing gaskets have a low coefficient of friction surface to allow for thermal movement of the glazing Continuous hinge bar with wide clearance for operation in dirty environments or where the building structure is distorted Can be operated by manual, mechanical or electrical systems Extruded setting shelf for glazing material allows venting of cellular thermoplastics • Double perimeter weatherstripping • Can be used in continuous runs up to 100 ft. long and 8 ft. high • When used in continuous runs the unique snap-together vertical joint allows for thermal expansion of the system Explosion release and heat release designs are available. Glazing • Glass or monolithic cellular polycarbonate or acrylic sheets From 1/4" (6mm) thick to 5/8" (16mm) thick Applications • Industrial and commercial/architectural use • Primary windows - New construction or retrofit (replacement) including: • Clerestory windows / Monitors windows • Venting skylights / Explosion (pressure) release Performance • Air infiltration: .09 cfm per ft. at 6.24 psf (50 mph) - (ASTM E-283) • Water resistance: No leakage at 6.24 psf - (ASTM E-547) • Structural: Tested to ±60.0 psf (ASTM E-330) • HURRICANE RELATED TESTING: Large missile impact test (9.5 lb. 2x4 at 34 mph): Passed • Pressure loading at 150 psf: Passed
Weiterlesen...
Weiterlesen...
