archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
No source of lighting is more perfect than natural daylight . . . and there is no better way to bring daylight into your workplace than through EXTECH® Skylight, Window and Vertical Wall Systems.Features• Monumental and heavy commercial thermally broken aluminum window• For glass glazing only• Heavy Commercial rated- HC-70 • Available in Fixed Project-Out (Awning) Project-In (Hopper) Casement (In or Out Swing) • The full AAMA test series was done using the smaller (2-3/8") framing• Will accept Glass or Thermoplastic glazings up to 1" thick• Anodized and long-life painted finishes are available for the aluminum framing• Factory assembled units can be side stacked (male/female mating)• Main Frames and vents incorporate poured and debridged polyurethane thermal breaks• Double perimeter weatherstripping• Use of 2-3/4" deep framing system allows for mating with other EXTECH systems and accessories
Weiterlesen...
Weiterlesen...
